case hytran equivalent
dixon700
pa
heavy truck mechanic
I believe the transaxle shuttle and brakes all on a 580sk call for case hytran. I will probably be changing the fluids shortly after purchase. Should I get the actual case hytran or does any hydraulic fluid that meets the case specs work?
melben
Williamsport, Pa
Retired 50 Yrs with Case dealership
I recently retired from a Case dealer with whom I have spent my whole working career(52 yrs). I have seen more damaged components, seals swelled up in hydraulic cylinders, excessive gear wear, excessive noise in geartrains,and many other oil related issues. Without going into specifics I was personally threatened with a lawsuit for recommending only Case products as several bought a brand popular here in Pa. that swelled the packings in our 580 series hoes so they had to be put on our rollback and pulled apart with a winch.
I fully expect to get flamed for this post but you asked, Being unsure of the quality and the meeting of Case's specs in the hydraulic clutch power shuttle and seeing that that oil bathes the brakes and lubes the bearings and gears as well as filling the torque converter, I cannot recommend any substitute with the xception of one. Right now there is discussion on YTmag's site about suspicion of shortline oils breaking down the adhesive in PTO clutch discs and pictures of a suction screen virtually plugged with seperated lining material.
In short, If I were running a later Case piece of equipment I would use nothing but Hy Tran Ultra. It cost one man on the Case forum thousands to have every lined disc in his 1370 ag tractor replaced from running a cheap oil. I could buy a lot of Hy Tran for what his repair cost. FWIW, I also believe HY Gard by JD to be a quality oil.
OK guys, no piling on now
Mel
mitch504
Andrews SC
Doesn't the Hytran Ultra also have additives to handle water differently than most oils?
How sure are you of Hygard's compatibility? not it's quality, but compatibility. I have thought about using it, since the Case dealer is 70 miles, and the JD store is only 8, and I use Hygard in my JDs.
north1
north dakota
Personally, I would use hytran ultra as I just purchased a 2006 590mII and plan to do the same. It is what is recommended in operators manual. I also use it in a case ih combine so already have it on hand though. By the same token, however; I have a versatile mfwd tractor that has the same transmission as case ih mfwd and it came from the factory with mobil 424, whereas same case-ih tractor comes from factory with hytran. So I use mobil 424 in the versatile tractor. I believe mobil 424 is a direct replacement for hyran and also Kubota udt.
lantraxco
Elsewhen
I had similar experiences when I worked for a Deere dealer with Deere machines and HyGard... In my opinion it's cheap insurance to use what the manufacturer says to use in drive train applications especially. The newer it is the more important that becomes also.
:my2c
willie59
Knoxville TN
Service Manager
Many years ago I had a customer that wanted an alternative in his 580 SK, I filled with a quality name brand oil and the machine developed brake chatter. Drained the oil, re-fill with Hy-Tran, no more brake chatter. I agree with others, it may seem expensive, but it's cheap insurance. Also, it's not like with the motor oil that you change way more often.
dixon700
pa
It's just I don't know of any case dealers around here... it's a kubota dealer I'm gonna be buying the tractor from... guess I'll have to see if they can get case hytran and get on the case site to find some dealers.
Deeretracks
Western Washington
Shop Foreman
Anymore I stick with OEM fluid as much as possible but I can state that I have run Hygard in place of Hytrans in our 580L and 580SM's w/o issue. They meet the same specs and are designed for the same uses. Plus, Hygard doesn't stink like the Hytrans does. LOL
dixon700
pa
Found 2 just under 50 miles hetricks and kahle. So if my kubota dealer can't get the hytran I know where to look.
JNB
North Texas
Flyin' low and rollin' slow...
I'd read somewhere that New Holland MasterTran is the same as CASE HyTran Ultra. It makes sense, but can anyone verify?
dixon700
pa
I've read that jd hyguard meets the hytran spec, but not the other way around so is hyguard held to a higher spec and is the best fluid? What is the best possible fluid for my 580k? Idt I should run travelers in everything.
dixon700
pa
I've also seen that Mobil 424 exceeds hytran spec.
rpyne
Lynndyl, Utah, USA
Our old 590 Turbo specifies Case Hy-Trans Plus (MS 1207) for the trans-axle, but I can't find anywhere, even the case dealer, that has it. What is the right oil?
amunderdog
Sunbright,TN
You can get just about anything delivered to to your door from WWW. Ineedthatthing
I live way out in the woods, so i understand.
It is difficult locating a supplier sometimes, But they are out there.
Bote
Kentucky
A bud has used Harvest King ($55 for 5 gallons from Rural King) universal trans-hydraulic fluid in his 580K for several years without any major issues. His machine is older but has half the hours mine does but he's always adding fluid. The previous owner of my 580M used nothing but Hytran from day one. The machine had no leaks so I figured I'd stick with the Hytran. I paid $99 for 5 gallons in December, but in 50 hours of operation I haven't added any. I'll stick with Hytran. Also, I believe Hytran is hygroscopic like brake fluid which means it absorbs water and holds it in solution. Some lubricants aren't so I'd be careful about mixing.
alrman
QLD Australia
Hy-Trans Plus (MS 1207) has now been replaced with Hy-Tran Premium
...... Case dealers that don't read their own literature - shouldn't be dealers..... :rolleyes:
You will also need to add 3 x bottles of Axle Additive (402982A2) ..... which they also won't know about.....
RedRanger06
Nevada
Tell me more about this Axle Additive.
From your post it seems the Hy-Tran is good for the Power Shuttle but needs the additive in the transaxle?
For reference I've got a 1990 580K.
gggraham
London Ontario Canada
Licensed Heavy Duty Equipment Mechanic
Mel
I also worked at a Case dealer for 30 years. On the later models use Hytrans Ultra Only. I agree with you totally.
Coaldust
North of the 60
I think we just had a Mobile 424 vs Hytrans discussion not too long ago.
