Good thinkin V..
Yes, get it started and with the engine running, operate the throttle with your hand..
And if it has a pull cable for a shut off, make sure it’s all the way open..
Next check and change the fuel filter..
If that doesn’t change anything, it’s time to remove the pump top cover to check for a stuck metering valve..
Google mv to see what your looking at/for..
