CASE DL550 Minitour at 300 hours
KSSS
excavation
I purchased my DL550 last December, its a 2024 model with rubber tracks. I have spent about 65% of its time with the dozer on. I will discuss that performance first. We have pushed about 12K cy with the machine on two jobs that we tracked the cy. I can average about 750-850 cy of virgin pushed material per 7 hours, that includes some ripping. I have the dozer set at 114 hp. CASE did a great job with this machine as dozer, the control handles, the features that are available on their dozers are available here. 6 way blade, blade shake, fine control, its incredibly intuitive. There is a lot of talk on You Tube about ability to hold grade with it. It took me about 4 hours to hold a decent grade, now I can do it in my sleep. I have very little dozer experience prior to owning this machine. The weight of the machine I think really makes this a productive dozer, it has great tractive effort, and pushes a lot more material than I was expecting. The rippers are very helpful, and well thought out. You can preset the number of gears the machine has in Dozer mode. I have it set at 16 and I like it there. You can preset the reverse gear speed. If you want a two speed increase during reverse, you can set it at that you want a three gear increase during reverse, you can set it for that.
When it doesn't have the dozer attached it is running a bucket or the Sharp Grade G128 grader attachment. The SG grader and the DL550 were made for each other. You can push an incredible amount of material, the tractive effort available makes it very productive, both cutting subgrade and finishing subgrade materials. When I
envisioned these two pieces together, I thought it would positively change how we did site grading, Neither one has disappointed. The DL550 has yet to make it back to my the shop since Feb. when it was first put on a job. It can and does everything. The bucket that came with the DL550 was a 1.25 cy HD bucket. It could easy have a 1.75 cy bucket and have zero issues. The machine plays with 1.25 cy It has a very high lift height, loads trucks very quickly.
The machine was very well thought out, when you spend time in it, you quickly realize that the development time on this machine, was very well spent. They thought of nearly everything. Considering the machine is a first of its kind, they missed very little. The machine can be preset with two, three or four speed settings. It can go from High and low, like they all have, two low speeds and one high or two low speeds and two high speeds. I really like that feature. Two engine HP settings, 85 or 114. Comes with 4100 PSI and 42 GPM on high flow. The machine has what seems like a countless number of setting options. If you want to fine tune how it responds, you can absolutely do that.
The only issue I have had with the machine is the fan. I am on my third. This last one is a new design and hopefully will stay together. The other two destroyed themselves. Luckily and hat tip to Titan Equipment, I had a new fan installed in under 24 hours. One came from La. and the other from CO. One of those occured in a very remote part of Idaho. I couldn't afford the downtime and Titan delivered.
Overall thoughts...I paid about 140K for this machine. Prior to purchasing the DL550, I spent a couple days at the CASE Tomahawk customer center in Wisconsin. After spending a combine 6 hours on it there, listening to the CASE operators telling me how to run it effectively, I could see the potential of what this machine could do for us.
I underestimated how impressive it would be. It really does everything you could reasonable ask it to do, and it does it very well. It has expanded what we can do and how fast we can do it. I plan on using on a mulcher as well, which I haven't had an opportunity to yet, because it was tied up with other things. I could see adding another one next year, that one will have single grousers. Seldom does a machine live up to the hype, but in this case, I think it exceeds the hype. If anyone demos one, you really need about 10 hours on it to learn all that it can do and read the manual on it. I have never really done that before, on any of the probably 25 CTL'S and SSL I have bought over the years. You need to on this one.
There are a couple things I would like to see on it. The control handles need to be expanded to offer more options for electric/hyd control switches. The control handles on CATs 285 would be perfect. It could really use more cameras. This thing is huge, and having side cameras would be a help.
Deere500a
Castro Valley ca
watching YouTube that Case is neat I'm mixed on skid steers from time of Bobcat 753/863 series to get in a modern Cat 279d with a 6way blade I'm sure ol 931 4/1 would have been easier & faster. It was a new site,hole was dug for a retention pond I had to slope it started with a 330 excavator it got pulled left me with 279 boy it was a pita plenty of power no waight on the blade,no down pressure with loader arms had to use bucket tilt change the cut wash board & wide rubber tracks moisture on the ground turn into a toboggan backing up & down blade dig in & try go sideways wrong machine after found out D6 was available from the start. Fine for parking lot gravel spreading
Georgia Iron
USA - Georgia
Ksss, what is the weight of the machine with the sharp grade attachment and bucket. What do you transport it with?
KSSS
excavation
The SG weighs around 3500 pounds. The DL550 weighs 18,600, but I believe that is with the dozer. I have not weighed it with just the bucket. The bucket is pretty heavy, I guess around 1K. I use a 24K Diamond C 35' gooseneck trailer pulling it with a '20 Chevy 3500 Duramax DRW. I also use a 28', 3 axle Diamond C 24K tag trailer to pull the DL550 with bucket and dozer.
CaseFan13
Flatwoods, Pennsylvania
I’m sure you have your reasoning, but what was the thought process on the SharpGrade blade vs Leica 2D on the 550 blade? I’m surprised Case hasn’t made wings for the blade like Deere with the 333.
KSSS
excavation
My thoughts were that a grader type blade would leave tighter accuracy, a better finish and its larger so it can cover more ground. I built a bracket to hold the prism on the dozer blade. It's indicate only, not tied to machine control, but I can rough it in with the dozer and finish with the SG.
Doing it that way is certainly an option, If I was only using to build pads and so forth, I think it would work well. I believe though for asphalt and concrete prep, that the grader blade is a better /tighter finish.
Having wings on the dozer blade would be a help for finishing work.
