Const&demoPA
I had a CX210 dropped of at a demo job yesterday. I went to move the machine today and found out it's set up for CAT controls. I have always run Deere so I am not going to have a very productive day Monday unless I can change it..I searched around a little with no luck and the rental company was closed...I have haul trucks showing up long before they open Monday morning so need to figure out before then.
The sticker on the window indicates it has the option to change controls. After checking under seat, behind seat etc.I searched around the battery compartment behind the cab where the hydro lines run into manifolds and didn't see anything obvious..I have searched past threads but none I found were for this model...guys did seem to think it would be in the compartment behind cab where I checked or under the floor mat for 135/160 models...anyone have the answer? would the model year(which i don't know) determine if it may have an actual valve or if lines would need to be switched?
Thanks in advance!
Thanks in advance!
