AtlasRob
Ok, Heeeeeeeeeeelp Please.
I would normally add this to the running thread involving this machine but its here on its own as I hope it will help others.
Got to the machine this morning and it was dead as a dodo! not a glimmer on the dash.
No drama its been down to -7C and the machine hasnt been touched for two weeks so it was well within its rights to have the hump in my opinion.
Only have 12v on the van so hooked that to one battery with the intention of having a brew ( cup of tea ) then hook it to the other and hope for a start.
I checked the dash with 12v now pumping into one of the machines batteries and still nothing should be something if only a glimmer :beatsme
Disconnected the jump leads and touched the ends together to see how dead the machine was. Had enough juice to start welding, so it isnt the batteries.
Its been wet and its been very cold.
Next to the batteries and behind a cover is this. I went here as thats where all the wires go
Found 3 of 20a fuses and 1 x 65a... all OK :Banghead Couldnt be something easy like a fuse.
I dont know what this gizmo is but 24v in and out at the top and a few little wires at the bottom,...... its comming off,..... and it did.
I sat in the van with it against the heater, dont know why but I thought that might cure it. It warmed me up anyway.
Bolted it back on, reconnected everything and.................still no power.
Time to check the ignition switch, so off came the right consol top.
The plug showed me 4 wires. 2 of them the same as 2 on this gizmo.
Sorry about the focus.
Right wire is white with a red line.
Middle is green with a brown line.
For some strange reason, I suppose I had decided they were supposed to be feeding the switch that was dead. I decided to touch a wire between the battery + and the right wire which resulted in a CLONK made by the gizmo and a buzzer in the cab. When I removed the wire it CLONKED again and the buzzer stopped.
I checked I had connected the ign switch and with the key in the on position tried again.
WE HAD PASSWORD request ( thats the immobilisor ) but a buzzer sounding. Sod it, try it.
It started but I was convinced that when I removed the power from the small wire it would stop. It didnt. So I turned the machine off to make sure it would stop and the buzzer was worrying me. It stopped.
Severe head scratching time.
I tried the + to green brown wire and got a CLONK from the gizmo but it didnt clonk when I removed the power, while scratching my head there was a CLONK and the buzzer stopped. Time delay. Same as delay in dash clearing when the ignition is turned off me thinks.
Connect + to green br wire and start machine, remove wire, machine still running, dash looks ok, throttle works but buzzer is doing my head in and starting to worry me.............................. Spot quick hitch switch has been activated, turn it off, buzzer stops :Banghead
Replace right consol and work machine.
What is the gizmo and is it that I need to replace.? OR is the ignition switch faulty. After running the machine for a few hours I stopped it on the key. It immediately activated the beep, beep, beep to say the immobiliser was activating and then was dead as a dodo again.
+ to green br wire and she fired straight up.
ADVICE please. What do I need to order.
DONT SAY A C@T
DONT SAY A C@T
