Thanks for the help. I received a complete repair manual with the machine, but it does not seem to match what I have. It says 888 case but pump and plumbing Im looking at do not match the book. So I'm flying blind.If you have a hydraulic Schematic and pos it to bucketsense@gmail
Uffex
Rexroth has totally different regulator design and lay out! The one on the picture either Kawasaki or HPV, althoug I’ve never seen regulator off of KYB pump which I’ve seen on some Sumotimo/Case excavator.This picts is from a 1088 does it match?
KR
Uffex
No it has one large pump with a smaller one piggy back and then what I'm assuming is pilot pressure at the tail. I'm thinking the piggy back pump is the one for rotate, since that still worked correctly. I pulled the main pump and replaced it. Machine operates better than I have ever felt it. I think the swash plate must have been jammed when I got it. I just assumed it was the way an old machine felt. Well its a smooth operating machine now! If that was the servo piston control fork that would make sense to me. I'm thinking swash plate went to flat when that broke and we came to a stop.The picture is bad but it kinda looks like broken servo piston control fork. Does you pump look like this?
http://global.kawasaki.com/en/industrial_equipment/hydraulic/pumps/k3v.
it was included when I bought the trackhoe. It has a tag on it. I took a picture, but its illegible. I can take a pic of the one I took out.Where did you get the replacement pump? Didn’t they tell you brand, model and size?
No, mine doesnt have any filters attached. But the drawing in my maint manual showed it like that. Did they come with 2 types, or has mine been swapped?Hey Dave does your hyd. pump have two filters attached to it? If so then you have a Lindie pump.
