GaryHoff
You just have older software, so "CAL POT" is for the brake pedal, and "CAL INC" is for the decel pedal.
Remember to move the pedals slowly up and down, within 15-20 seconds. This procedure may take multiply times to complete, as it is fussy. It will not complete the calibration, if the brake POT is out of range.
It sounds like your brake POT is out of range. You will have to back probe the connector, and check the voltages. Adjust or replace it as needed.
Engine RPM range is 2170-2270rpm at high idle no load.
Low idle is 800-1050rpm
