Jon Bradtke
Hello all,
Newer member here so if I miss something please be kind. I have a straight 850 dozer that needed an engine rebuild. I have the engine stripped down and heads were rebuild/machined. Crank had to go to 0.030 Under based on wear. I ordered the engine rebuild kit and started to swap the liners and pistons.....surprise!! My liners didn't fit and were not large enough in diameter. Turns out someone swapped the original 301BD for a 336BD. The engine serial/model tag was missing which didn't help my situation. I'm going thru the process is validating the fuel system but I need the engine serial number for that portion.
Long story short can the engine serial number be identified from the injection pump serial number?
Injection pump info from Tag on rear of injection pump.
R5V 375 - 1100A2B2078R
CASE NO. A154779
Thanks for any help!
-Jon
CASE NO. A154779
-Jon
