I have a '97 621B, with 5000+ hrs., that i am having a similar intermitent tranmission issue as well. I can jump in it and run it easy or hard for 5 minutes or 5 hours and all of a sudden the trans. defaults to a neutral state. I have replaced all of my grounds and cleaned all of my connectors, they all look good so far, have not actually ohmed any of my solenoids yet. Has anyone found any "common" problems with this issue that seems to pleague the ZFs??? I am planning on, when the fault occurs next time, pulling the "trans cut-out relay" from under the dash to potentially elliminate the possibility of the brake pressure, park brake, and declutch switches from being the intermittent issue. As my service manual shows, these switched features are all powered through that relay and the machine should run and shift with it removed, obviouly I want to duplicate the issue first. Thanks
