I decided to fix all the hydraulic leaks on the backhoe. The first one was a "learning experience" but I got it completed and worked my way through the rest of them. Along the way I bought a gland wrench and some large box wrenches. I was feeling pretty good about things until I got to the last cylinder. It's the stabilizer (largest diameter on the machine). Immediately I noticed the pin holding the rod would not budge. I removed both snap rings and tried numerous hammers. It won't move at all. This is the pin holding the hydraulic rod. I've spent days covering it with PB blaster and another oil I read about (I forgot he name but it's super thin and red). Still couldn't get this pin out. I was about read to grind the head off the pin to see if I could remove it. I stopped and just released the hydraulic cylinder on the opposite end where it attaches to the backhoe frame. I know that's not the best solution but "in theory" it should allow me to release the cylinder to replace the seals. This is where the REAL TROUBLE BEGIN! I've tried everything to remove the gland nut. I used an impact wrench with the gland wrench. Didn't work. I bought a 36" pipe wrench and put a 5' cheater on it. Didn't work. I applied more solvent and PB blaster and let it sit for days. I tried heating the cylinder (only had a plumbers torch with MAP gas). I tried hitting around the area with a sledge. I tried using a chisel in the gland holes. Nothing has worked. I finally put a piece of 10" metal conduit on the 36" pipe wrench. Still did not work. I'm out of ideas and I've about resolved myself to the fact I'm going to have to ruin the gland nut to get it out of there. I was going to try cutting it with a hacksaw (starting at the face and cutting through the 1/8" (or so) of metal) thinking if I removed about half of the face of that nut then It might release it. Has anyone ever tried this? I haven't done it yet because I got thinking; the treads are not in the area I'd be cutting away so it might not accomplish a thing by cutting it. Is there something I've missed? Any other suggestions? Can you remove the gland nut by cutting it?
