Case 580L 2wd
tom97
CT
My case 580L 2wd has a worn out front axle. Kink pins wore into axle, my spindles are good my question is where or will I be able to buy a good used axle? I have seen new aftermarket for sale but I am afraid of aftermarket fit. Thank You
alrman
QLD Australia
These axle housings can be repaired. I have welded many of them using nickel rods. Usually one half of the hole is still in reasonable order & the worn section can be filled by welding & careful grinding using carbide burrs & a fine grinding stone on a die grinder, similar in size to the bearing cup.
Ideally this should be done in a machine shop & properly bored - for a perfect repair. But time is money & such a repair is very expensive.
Most of my clients opt for the 'on site' get me going in a few hours option...... most of these repairs have have lasted for quite a few years, with full time contractors.
bob_00
QC, Canada
thanks for your reply alrman i have the same problem on my 580k looking for idea to fix it and you came up with a good plan
