CASE 580D return to dig
JohninAK
Fairbanks Alaska
I need some help diagnosing the RTD solenoid, as I think that's the problem.
I replaced the microswitch mounted on the loader frame, wired it on the NC side of the switch. I have B+ to the blue wire at the switch, continuity to ground on the black wire. I have continuity between the switch and the solenoid wiring, I have 6V at the solenoid, assuming that is due to the resistor in line.
No action at the solenoid when I manually work the switch in KO....?
Assuming the solenoid has failed, any help here?
Thanks, John
Coy Lancaster
Arkansas
service tech
Have you check the solenoid with an ohmmeter? I don't remember a resistor in the wiring harness for RTD, you should be getting 12v at solenoid.
JohninAK
Fairbanks Alaska
I have power to the solenoid, all the wiring and connections are good.
I am going to assume it is the solenoid or as Case calls it "detent". N6581
Shimmy1
North Dakota
Having some trouble finding that part, maybe will see how I get along with out it
Loaded trucks for 20 years with 680E and 780C. With the Case linkage, all you need is a pointer attached under the bolt head that you adjust to line up with the bar to the bucket when it's level.
This one looks like it's missing, but it goes right here.Screenshot_20240508-231327.png
JohninAK
Fairbanks Alaska
There is a bucket level witness mark that I had not noticed before, Thanks!
I am sure I will get the hang of it.
I bought this machine last year and spent some time this winter pulling some maintenance, fixing the door, fixing leaks, changing fluids, replacing seals and centering pins / bearings.
Broke my leg in February and set me back two months, pulled it out of the shop last week and pretty happy with the old girl.
We had the backhoe completely off for a number of reasons, had to adjust the foot swing pedals.
What I noticed on Saturday when swinging left / right is, it doesn't slow down when it gets near the end of the swing? Seems like it should, is that just a pedal / linkage adjustment?
