Took the boom cylinder apart to repack it and found the rod was bent and the piston was scored, I'm assuming the cylinder wall is scored the same amount. I'm thinking with the amount of scoring on the piston that honing the cylinder enough to smooth it out might cause fluid bypass. I'm attaching a pic of the piston, do the grooves look too deep to hone the cylinder smooth? Does anyone know if these aftermarket cylinders are any good? They are a lot cheaper than the OEM's I've seen.
Ebay Link
Ebay Link
