Festeraxp
- Joined
- Jan 7, 2019
- Messages
- 80
- Location
- South Central Pennsylvania
- Occupation
- I walk the toughest blocks in State
No, not the manual in the photo. That clearly says it is a series B manual.Yup I figured some of them out but thanks for the reply. Now to get the tachometer out of the block. You mean a manual like this?
You are OK. That was probably the broken off end of the cable core you pulled out.that center piece is the one I pulled out already. so its just a small hole where the end of that drive used to be.
Yes. I posted a drawing of the puller I made a few years ago. I will look in my shop for the puller. If I can find it I will post a photo of it.so all I really have to do is screw a bolt into that housing hole and then try to pull it out?
