Funny farm
- Joined
- Apr 21, 2018
- Messages
- 206
- Location
- Ontario Canada
- Occupation
- Red seal,high pressure certified welder
Hi. New to the site and fairly new to heavy equipment. Bought a backhoe a couple years ago and a few months later it started to knock badly. Stopped running her immediately and after several years of looking I found a replacement engine. Wondering what i should replace on the “new to me “ engine before installing it. Rear main seal? Other gaskets ?...?? Or just install it as is ?? Also should I replace and seals like the converter seal? ( I have a power shuttle unit ) Any help and tips would be greatly appreciated as I’m a bit unsure as to what I should pay attention to and what I can leave be. Old engine runs and has good spare parts but has a crank/ rod knock. With the cost of a crank and rebuild I decided to start with a diff engine and hope for the best. New engine is claimed to have about 3000hrs and was pulled from a running hoe. It has a clutch and flywheel that I will need to swap for the one off the original engine as it has a converter not a clutch. Any tips on swapping the flywheels around ?... I notice a few small diff in the engine castings but they r both 188 engines. Thank in advance for any help. Heading out now to continue preparing for the split. Old engine is almost disconnected now. Just the steering rams, fuel lines and throttle rod , hyd pump and radiator to remove and a few other small things. Then it’s time to block the old girl up and split her in half. Never done this before and I’m working in a gravel driveway so fingers crossed it goes ok. Gotta use what u have and unfortunately I don’t have a shop or a cement pad , so level spot on gravel lane will have to do. Lol
