Chris580c
Hey y'all my case 580c slowly stopped going into fwd gear . if I'm going downhill its fine, but flat land and up is a no go. Read so many posts I'm more confused than when i started. I have drained it pump was clean reassembled and filled with prem tractor fluid. no better. Reverse is still strong, but I'm at a loss were to go from here. Ive read that it may be the linkage, but moved the lever fwd manually to no avail. My guess is that if it was bc i dont have hy tran in there it would be the same problem in reverse. IDK if thats accurate or not btw when on stabilizers tires spin fwd and reverse. just not on ground. please help and thanks in advance
