john adams
Ok so my 74 case 580c had the injection pump all gummed up, i pulled it and got a kit a went through it. it runs and starts good but has a miss in number one cyl., i tried two of the china junk injector nozzles but no change, i checked valve clearance and it was good, i bought a Stanadyne new injector nozzle and still missing and a bunch of white/fuel smoke out the stack. after ir gets warmed up it is a bit less but still too much. Is there any way for the Roosa Master pump to over fuel on only one cyl. ? Before the fuel went bad and gummed it up the engine ran great, no smoke ,no missing. Maybe im an idiot but i did not test the new Stanadyne nozzle to check calibration, i did test the china ones and they were 3300 psi pop off, book calls for 2800 if i remember right, where did i go wrong?
