Case 580C Hydraulic Oil
Tinkerer
usa
Yes you can use it. It is not a multi grade. It is the equivalent to SAE 20.
JBrady
NE OK
My 590SL has 8 different places for oil. Which one are you asking about? The only place I would use that oil is to top off the hydraulic oil tank. Hy-tran ultraction for the real axle and converter and gear oil for the front axle and rear planataries.
MartinDR1025
Alma, Ga
Traveller Premium Universal Tractor Trans/Hydrauilic Fluid is a specially formulated, premium multigrade (SAE 10W-30) fluid blended with the highest quality lubricating oils and the most technologically advanced additive system.
  • Provides superior protection and performance for modern farm equipment
  • Employs a common sump to lubricate hydrostatic transmissions, differentials, wet brakes, hydraulics and final drives gears
  • I need it for the front bucket/backhoe hydraulics
Tinkerer
usa
My bad !
I missed the Premium part in the first post.
Premium is indeed a 10W-30.
I prefer AW32 (10W) that meets backhoe specs. because of it gets sooo dam cold in the winter where i live.
10W-30 is a good choice to use in Georgia.
I pay about the same price as the TSC oil.
