fred580c
Just got may first backhoe on a barter. After working on it for couple days I found the camshaft is broken flush with the front of the engine where the gear is mounted. There is tooth damage to the camshaft gear teeth which appears to be from the hydry pump (1 1/4") gear on top left. So, my dilemma is that I am not a real mechanic and would like advice as to what to do. I know someone who can replace the camshaft for me but what else should I do while im in there....do buy a rebuild engine to replace it? let him just replace the cam, do I do the lifters/push rods/ pistons etc. Im not sure. also, did the cam break because there was too much force on the hydro pump or what? I will welcome all opinions!
