Coy Lancaster
I welded a piece of 1/2" allthread to the plug and found a piece of pipe that fit around the tach drive area and welded a large washer on top put the allthread through it and put a nut on it then used it as a puller. The weld broke later on in years and I haven't needed it sense so I haven't put it back together. I couldn't find the rest of it.
Another thing you can do which I just thought of is that you can weld a nut to the top of the drive and either use a slide hammer or puller.
