Blueacre
Just bought a Case 580 Super M Series 2 at an auction. The Anti Rollback linkage rod from the right side front loader arm was removed. I think I found out why - the 2 bearings are seized on the short rod that goes over the battery cover area and pushes on the loader control valve linkage under the cab. Had to put a 24 inch pipe wrench on it and lots of WD40 to get it to move.
See attached diagram of the Rollback Rod assembly I found online for a 580N - looks the same as my 580SM.
I removed the 4 bolts that hold the 2 bearings to the frame but there doesnt seem to be enough room to get the rod out without removing the 4 steel hydraulic line that run from the loader valve to the right lift cylinder and rollback cylinders.
Even if I can get the rod assembly out does anyone know how the bearings are replaced - the rod has a 90 degree bend in both ends and can't see how they could be replaced unless they are a split assembly ? I cant seem to find these parts anywhere in the case online parts list ??
There is also a torsion spring on the control valve end of the rod - one end of the spring is broken but I also cant see how a new spring can be installed over the 90 degree bends in the rod ?
Appreciate any input on how to repair this problem.
