case 580 Super E Banjo Bolt
rockbust
sc
Hi I started the backhoe today and one of the 4 Banjo bolts started sputtering fuel so i tried to tighten it but kept leaking. Then I used my super strength and sheered the bolt off. Fuel in the face and eyes.
Does anyone have a part number for this thing and know where I can locate one quick? Also and tips putting it back together so it does not leak. Sand? new washers? Thank you20220627_162423.jpg
tbird64
North Dakota
Hi thepumpguysc,
I did the same thing, sheared off a banjo bolt on the injector pump on Case 580k backhoe.
Do you more of the bolts & washers available?
Thanks!
What kind of washer do they have? If they're copper, then they work harden, to reuse them you want to anneal them first, which just means heating red hot with a small propane torch, copper doesn't harden with cooling, so you can drop them in water or let cool in air and they'll stay soft until they get deformed.
