MFCustoms
Good morning everyone. I’m new to the forum so I hope that I’m following proper procedure here; if not please don’t beat me up too bad over it. Im a heavy equipment mechanic and just started at a new place about 3 months ago so there are naturally machines that are new to me. I’m working on a Case 521D Wheel Loader that will not crank. The gauge for the oil pressure is blinking with one bar, the red stop light is on, the parking brake is on and there’s a constant chime approx every 15 sec or so. Also, there seems to be no communication between the transmission ecm and the info center as none of the displays for the transmission are showing on the screen. The machine will not crank. I’ve checked all of the fuses and relays, checked and tested oil pressure switch and pulled codes (70-90), which were:
47000: CAN Interface failure
86060: Info Center Reset
46246: Clutch Adj Data Lost
I’m not exactly sure on how to proceed as I do not have the ability to execute AEB. Any help you guys can provide would be greatly appreciated thank you
