Thank you for visiting HeavyEquipmentForums.com! Our objective is to provide industry professionals a place to gather to exchange questions, answers and ideas. We welcome you to register using the "Register" icon at the top of the page.
We'd appreciate any help you can offer in spreading the word of our new site. The more members that join, the bigger resource for all to enjoy.
Thank you!
So I just replaced the Injector pump and when I went to drive it the high low shifter appears that it is in neutral and won't go either way. Is there any trick to getting the gears lined up?
No gear grinding no howling. If I try to shift either way it just bogs the engine if it is running, and I can't find a place where it wants to engage if I manually rotate the drive shaft.
Took the linkage off and checked it. It was nice and free. I bent the lever trying to push it in to gear with it off. Thinking I may have to tear it apart.
It's not that easy to get inside the two speed housing on a 450C - brake housings & backing plates have to be removed to pull the 2 speed housing......
Not a good job!
There is a detent ball & spring for the selector, located under the housing.
Take a look at that, may be it's jamming the selector rail?
