Thank you for visiting HeavyEquipmentForums.com! Our objective is to provide industry professionals a place to gather to exchange questions, answers and ideas. We welcome you to register using the "Register" icon at the top of the page.
We'd appreciate any help you can offer in spreading the word of our new site. The more members that join, the bigger resource for all to enjoy.
Thank you!
we have a 445 series 3 that was running great until it was run low on fuel. Now at full throttle it will run great for a minute then start surging and puffing blue smoke. I have already replaced both fuel filters. Any ideas?
Both are correct.. easiest thing to do is pull the feed hose between the filter & fuel tank.. remove the fuel tank cap & back blow w/ compressed air.. Bleed the air outta the system & give it a try.. While bleeding the air, you should be able to tell the condition of the lift pump.. does it pulse fuel w/ every rotation of the engine..??
If it pumping, GOOD.. tighten it all up & run it.. It'll take a few minutes for all the air to work out of the system.. Good luck.
Thank you for the input I ,probably prematurely dismissed the fuel pump since they didn't run it out of fuel. However I will check both on Monday and let you know.
Sorry we got busy. I feel like an idiot, the supply line was obstructed. Really a rookie mistake, thanks for the help and guidance I over complicated the problem!
