I have a case 40xt (only 950 hrs) that had a very small leak out the weep hole in the water pump which the dealer said was an indication it was going bad. Went ahead and picked up a new thermostat while i had it apart since you have to drain the whole system and remove the radiator anyhow to get to it.
It never had any issues getting hot before, even with the slow drip out the weep hole. The temperature light had never come on and I've operated for about 70-80 hours over the last 9 months I've owned it. Now the last two times i've operated it since changing the pump and thermostat my temp light has come on. The first time I had been pulling honeysuckle/brush for a few hours and it came on. (Approximately 45-50 degrees outside).
Today, i was using my brush grapple cleaning up limbs from trees i pushed over with an excavator and cut for firewood and it came on in only about 30 mins. (its only 39 degrees out today). I immediately parked it in the shop and shut it down. The engine didn't feel that hot holding my bare hand over it and i could touch the side of the radiator for a couple seconds. It was hot but not enough to burn you.
I did notice two small trails of liquid in the dust on the belly pan on the right side directly below the radiator approximately straight down from the radiator cap but it was minimal and i didn't see it dripping off anything or pooled anywhere.
Any thoughts? I thought maybe my sensor was going bad but then that wouldn't explain the small trails of liquid in the dust below the radiator. Could the brand new Thermostat be sticking closed maybe? Or the radiator cap be going bad?
