bobkmd69
I posted this in the compact wheel loader forum by accident. Sorry. Bought a well used 1845C (I think it is at least mid 90's as it has the single safety arm) to help clear my land and dig a pond. I bought it knowing that it will need some work. The previous owner told me of the issues he had with it, which seemed to me to be minor (couple of hydraulic leaks and a box of master links for when the chains slipped off). I noticed it was making a popping noise in the front left wheel, so I removed the access cover and noticed that there was a lot of slack in the chain on the axle. The chain on the gearotor was fine. That's when I ran into a bit of confusion. I went ahead and adjusted the front axle to tighten this chain, which somehow managed to loosen the main drive chain off the gearotor. I tightened this one up, but then checked the rear axle and it was also loose. When I went to adjust this one, it was already as far back as possible, and the play was over an inch. Just to be more thorough, I checked the right side and it too is very loose. Is there a proper adjustment order to these chains, or does it sound like I might need to remove a link in the chain to be able to put it back into adjustment. Any advice would be greatly appreciated!
