Case1840BC
Hello everyone, I could really use advice how to proceed with oil dripping out from a 3/4" threaded hole in the bottom of flywheel housing. First thought was it is the main engine seal but then I realized it is the hydraulic oil because it is very clean compared to the diesel engine oil. If I got it right the oil from the tandem drive pump must be leaking around the splined shaft that slides into the splined coupler inside the flywheel housing. I searched the Case forum and so far I did not find anyone having similar problem so I am at loss what to do or how to fix it. The oil starts dripping as soon as the engine starts. I used an inspection mirror and saw few drops falling down from the hole followed by a short trickle, then nothing for a second, then again drops, trickle and so on. The skid steer moves no problem but going up hill it leaves an oily track behind and I have to keep refilling the hydraulic oil in the main tank. Did anyone had the same or similar problem and could share some ideas what to do? Thanks for helping
