Case 1840 hydraulic couplings???
stefuel
Marshfield MA
I'm adapting a Fisher power angle plow to my 1840. I've never used the aux hydraulics on this. The flat faced couplers at first glance looked like everyone else's AKA universal. I ordered a set on line, got everything put together only to discover they don't fit. The outside diameter of the Case male adapter is almost 1/16th larger then the one I bought. Also the recess on the male half that locks it into the female half is in a different location. Did Case have their own unique version of these couplings???
heymccall
Western Pennsylvania
Early Case used the Parker FF501 & FF502.
All of my Takeuchi, Kubota, Yanmar, Caterpillar, and Bobcat use the Parker FE501 & FE502 equivalents.
As you've discovered, they don't interchange.
You'd be better off switching the machine to the "FE" equivalents, as that's what's on everything now.
stefuel
Marshfield MA
You were 100% correct. Mine were FF's. The machine had special couplings with the flare part included that had a lock nut to secure it to the bracket on the machine. I took the full FF number off of it and tried to cross it but was unable to locate a complete assembly in FE. Went to the local hydraulic shop and bought a pair of 1/2 male IPS X flare adapters to fit the IPS FE's to the machine with a large washer to help hold it in place. The adapter tightened just before bottoming out on the washer so there's a tiny bit of looseness but usable with no leaks. Thanks.
