The BOSCH P# for the HP is> 2 447 010 038 and comes w/ a gasket..
Try "DCPCART.com" click on "industrial" on the left hand side.. its 10.00 [aftermarket]
I replace them 100% on an overhaul and have 100's of used ones.. BUT I wont be back to work till next week or 2..
thanks for the info.Sweet price and I assume you've had good luck with them. Since you are a pump guy, I have to ask-do you happen to know of a hand primer that will work on a V-8 Mack('85 998cu in)? I have a mack Magnum here, and its a little tuff to get started after she sits a while. There is a plug in the "v" of the fuel pump where a primer should go. I cant think of the pump name at the moment abac? ambac? abscam ?its the v shaped one with 4 inj port per side. Sorry for going off topic moderators, but I just had to ask-George
