silverstr8p
Today we were pushing on a road just like normal and my Case 1150H just died cold, like you pulled the key out and threw it in the bushes.
Then, if you keep the starter running, the engine will run, but when the key springs back to the run position the engine dies.
So, to move it out of the road so we could get the truck past, we held the starter running creeped forward, but to do that we had to use a piece of wire to hold the switch on the emergency brake so it would engage the transmission.
Then after a couple minutes it started working like normal again, but with about half power. Where should I start looking? It seems like maybe the fuel solenoid or ignition switch is somehow getting disconnected, like a wire fell off or a relay is failing or? Where should I start?
