I have just aquired a Case 1150 (C ?). I think it is about a 1980 model or so with about 4500 hours on the engine. The rear right final drive has some issues as the rear sprocket is loose. The machine is sitting on blocks and the I can pull the rear end of the right track 5-6 inches side to side, including the large sprocket/wheel back there. That issue is one I'm going to look into but first I was trying to start the machine today (never had is running, as I just aquired it, but last person that had it, whom I trust, said it was running with no issues on the engine side of things when they parked it). I put new batteries in it today and did the following;
-checked the fluids, all looked good
-turned on the key by the lower right floor board
-Amp meter registered about 13 or so
-Went to turn the ignition swich, and when I did there were sparks at the alternator and some smoke.
-I turned the ingnition switch off asap, and checked all the wiring up front but found no visual issues.
-When I turned the key back on again, the amp meter registered amps for a second then "shut off" back to zero.
-I could hear a slight click almost coming from somewhere behind the dash.
-I turned the key on and off serveral times and each time it did the same thing.
Can anyone tell me where I need to start in an effort to find the problem? Is there a common weak selanoid or relay by chance I should look at? I am no electitian but can work through problems usually if I know where to start looking.
Right now I have the batteries pulled.
Thanks for any help you can provide. At a later date I will be posting to look for guidance on the final drive issue. Again, thank you for any quidance.
Rex
Rex
