Does anyone know the reason for intermittent lock of the right hand side track?
When shifting normally from forward to reverse or reverse to forward, the right track will lock up as if the oil pressure is feeding both forward and reverse clutches? If you wait for 2-3 seconds it will consistently shift OK.
The case SN is 7301728 and is the old Case 1150 model.
Transmission pressure is consistent from 210-265 PSI, torque converter pressure is 45-50 PSI
Any ideas? I'm hoping its something simple..
Many thanks!
Many thanks!
