Can someone identify this bearing?
ps66x4
CT
cement mason
It's a Magic screed as far as I know there's only one model
Well just from a quick check online I'm seeing several models.
Just an example of the gas engine models:
https://allenengineering.s3.amazonaws.com/2022-08/MAGIC SCREED Manual UpdatedCovers.pdf
Looks like all those use the same shaft assembly (10026) that I'm guessing is the shaft/bearing assembly you are looking for you machine. Might be worth a call to the company or look on this site for a dealer:
https://www.alleneng.com/
A quick look for dealers in Conn shows three.
heymccall
Western Pennsylvania
Kinda amazing how that tiny tidbit (name) can help us .....
Now that we know that it's a $350+ part, we can keep going down the rabbit hole trying to break it down.
And the whole book...there are variants within.
  • magic-screed-GX35-parts-list.pdf
heymccall
The pic in the first post was "borrowed" from an Ebay listing, which, ironically, is the lowest price I see.
  • Like
Reactions: DB2
Coaldust
North of the 60
This thread reminds me of that great Chevy Chase scene in the movie, Fletch.
Hey! It's all ball bearings nowadays. Now you prepare that Fetzer valve with some 3-in-1 oil and some gauze pads, and I'm gonna need 'bout ten quarts of anti-freeze, preferably Prestone. No, no make that Quaker State.
  • Like
Reactions: DB2
I have a feeling that that shaft assembly/bearing is a stock item and if you can find a source for it from a bearing company it will be about half the price the screed company is asking!
I'd be taking it to the nearest big city and visit some bearing supply houses. Then when you walk in the door look for the grouchiest looking grey haired guy and talk nice to him! If he has a name tag on call him by name and ask for some help.
ps66x4
CT
cement mason
I'm in communication with SKF and waiting on what they have to say.
ps66x4
CT
cement mason
I found one 1.5"x2.125 like the one that was there, input needs a little machining and I'll have to fabricate the counter weight but the bearing is less then $50
ps66x4
CT
cement mason
I would rather find an oem at reasonable cost. I won't be gauged
ps66x4
CT
cement mason
Nsk885801SE Water pump bearing will work. Cut both ends to length, drill one end and broach it 1/4" hexagon.
Axis 885801SE bearing is the same size just I never heard of them.
ps66x4
CT
cement mason
I couldn't find the Axis 885801SE on Ebay for the $16.75
ps66x4
CT
cement mason
I found out the difference between the 885801SE and the 885801 is the 885801SE is not a tempered shaft. Which is the one I need so I can cut and drill.
