chuck jacobs
tractor has been sitting, and i want to make sure that no water got in through the exhaust. want to remove injectors,crank engine over a few times, too blow any water out of the cylinders. drain engine oil and replace it with a new filter.get the thing started turn it around using the hoe to pivot the machine. only moves in reverse.then i can back it into the polebarn. and finally rebuild the reverser,pretty sure foreward clutches are shot. just dont want to damage the engine on start up.are any special tools needed to get them injectors out. if you could send a picture it would be great.i would purchase the cd if i knew the best place to get one. thanks alot guys .melben sent me a message about the reverser,now im ready to atempt the rebuild:drinkup:drinkup:drinkup
