PeaNutz321
Can a stuck check valve cause fuel to leak into the engine oil or do I have two separate issues?
Injector pump shaft seals or the supply pump. The IP seal type depends on which manufacturer.Case 580c
I’m new to diesels. It seems to crank and run fine until it fills with diesel then there is some smoke. We drained the diesel/oil mix out and put new engine oil in. We were going to pull the pump but discovered the check valve with the glass ball on the top of the pump was stuck. We cleaned that and got it working reinstalled that to see if that might fix the problem. Probably wishful thinking. So it was ran for a little while and parked for few days when I went back to check the oil level it was a little higher up the dipstick but not real bad. There was a little white smoke but it still ran fine. I was told that it was the front seal that is leaking. I’m not sure if the pump was pulled previously or if they were guessing that was the problem. I’m hopeful it’s the umbrella seals. But it will be a few days before we can work on it some more.It depends, is your engine smoking like crazy to the point of wet stacking? If it’s not, I would then check the seal in the drive end of the pump. Maybe best bet would be to get some fuel dye a
nd then round the engine for a bit, then remove pump and check for the dye at the drive gear. You may also want to check for bits of debris blocking up the return fitting on your pump first. If there are bits of plastic plugging the fitting it would be why your front seal has failed and also means your pump will need a rebuild. A faulty injector would need to dump a lot of fuel to really be noticeable in the oil. Usually only a failed oring in a cam actuated system would cause that.
stanadyne db0431aj3205Injector pump shaft seals or the supply pump. The IP seal type depends on which manufacturer.
Thank you. I know this is unrelated. Everything I read says tie throttle/governor open before removing pump…the diesel mechanic says he never does this. Can you tell me why it’s recommended? I’ve read that it makes reinstallation easier. He says it only goes back on one way. I know nothing and don’t want to argue with him when he’s the expert but I would like to make the job go as smoothly and quickly as possible.Flex ring failure will not put fuel in the oil..
It clogs up the return connector (glass ball and spring) and shuts the engine down.
U can look for “coffee grounds” in the connector or if your feeling froggy, pull the side cover gasket and it’ll be wadded up in the corner.
U can hold a wad of paper towels under the cover and let the fuel run over it & it’ll catch the “mouse turds”..
