stock
Well called to see my kin at home on the range and instead of finding him milking he had ripped up this 684 that he had bought for a song
The reason it was so cheep was that the high gear range was unobtainable and the previous owner had come to his limit of spend on the tractor ,engine rebuild,clutch .splitter gear ,hydraulics and brakes had all been done and then the gear issue,What had happened was post to the rework the tractor slipped between two gears due to loose linkages (common Problem on this model)and was forced out through the use of brute force and ignorance.
The result was a broken roll pin #6 on the selector shaft #11 ,this pin held the selector shaft in place forcing the selectors #1 & #4 to move independantly when it broke the two selectors moved with the shaft and tried to engage both the high range and the low range only when selecting the high gear.
so now the issue has been Identified it will be repaired tomorrow and the few other minor complaints will also be fixed .When finished it will have cost him the grand total of e500 .
The one below is sick with a rear crankshaft seal leak
and a future project
Stock
Stock
