Cab Hydro Controls only work when engine is full throttle. Any less RPM=Nothing will operate / No track movement or bucket movement
NORTHCOASTLLC
Lynden, Washington
New here. Working on my old LIEBHERR 945.
Hydraulic tank is up to the proper level.
No obvious leaks.
I can post some photos if that helps.
Thoughts?
Thank you in advance
^Was thinking that if it is pilot contolled then the pilot pressure was the problem ^
They make a new R945 to confuse the searching, but I found this video posted by @skadill a year ago that looks like the right thing.
It appears to have pilot controls.
NORTHCOASTLLC
Lynden, Washington
Update
Received my new hydro pressure gauges today. My basic plan at this point is to test the pressure from the pump at low rpm and then at high rpm. Hopefully see some proof of whats not doing what it is supposed to do.
NORTHCOASTLLC
Lynden, Washington
Anyone have advise for us when hooking up the pressure testing gauges? Here is a photo of what I'm looking to tap into. Does anyone see a pressure relief valve in this photo? It would be great to test specific functions and pressures without having to drain the reservoir tank in order to remove the pump for visual inspection of the internals.20231206_105323.jpg
aongheas.macask
Scotland
ex service manager
Anyone have advise for us when hooking up the pressure testing gauges? Here is a photo of what I'm looking to tap into. Does anyone see a pressure relief valve in this photo? It would be great to test specific functions and pressures without having to drain the reservoir tank in order to remove the pump for visual inspection of the internals.View attachment 308379
PRV will be on the spoolblock x 2
aongheas.macask
Scotland
ex service manager
Please tell us where or what the spool block is. We don't have a lot of experience with this.
Follow the hoses from the hyd cylinders, they go to the spoolblocks. Perhaps you should employ an experienced mechanic before messing about with high pressure hydraulics.
I understand you have no experience but if you have zero knowledge then hooking up pressure gauges without knowing what you are looking at will be pointless in my opinion
NORTHCOASTLLC
Lynden, Washington
What I meant was I haven't had much experience working on this excavator. The knowledge base in my shop covers everything from race cars to heavy ag equipment. This Leiberr is an old girl and I can't find a service manual anywhere. Can we confirm that what we are looking for is not in this photo?20231206_105323.jpg
NORTHCOASTLLC
Lynden, Washington
I removed and disassembled the PRV. Not seeing any damage. See photos
Photo #143642 shows wear but nothing major
NORTHCOASTLLC
Lynden, Washington
Progress. I got my new pressure gauges attached to the testing manifold. At wot the gauges show ample pressure. Everything operates.... a little jerky but not bad. When I back off the throttle 20% the gauges show nothing, everything stops working. After researching the Linde AG main hydraulic pump B2PV105 it looks like a rebuild kit is available for about $1,500 usd from China. Has anyone on this forum ever rebuilt this type of pump? I have searched everywhere for manuals but can't find anything. If we have to pull the entire unit from the excavator we have the machinery to do it. However, it would be amazing to find out if the unit can be rebuilt / repaired by opening up the case when it's still in the excavator. I realize this might be a long shot but worth looking into. I will attach a few photos with some red labeling. Not fishing for free spoon-fed advise. We are happy to pay for direction with this situation. It would be frustrating to pull the entire pump and find out the repairs could have been made while it was still in the excavator. I am currently rigging up a larger pressure test system that will be right at the pump pressure outlet. Probably worth the effort to make sure the main pump internals are the problem.
aongheas.macask
Scotland
ex service manager
The kit in your photograph is only the main barrel and pistons, this is not a rebuild kit,,you will require two of these,plus servo shafts,bearings,seals etc. The pump will need to be removed for overhaul/rebuild. Linde made good pumps and I suggest you contact them or one of their distributors. A good hydraulic shop should be able to overhaul this pump but I would be very wary of using Chinese components from a quality standpoint.
NORTHCOASTLLC
Lynden, Washington
Update
Local Hydraulics tech had the following input. If the pressures meet specs at full throttle there probably isn't anything wrong with the pump(s). He explained how there was a hydraulic system on top of a hydraulic system in this Lieberr. He explained in more detail. We are trying to find the valve, or vane that adjusts pressure depending on throttle position. Does this sound familiar to anyone?
