wrench23
i have a 2007 kw t800 cat c15 low oil pres at 20 psi at at idle if you rev to 10grand, warning lights come on if you check oil its right at the line! i changed the filter, a week later happend agian...... changed oil and filter and agian ........week later happend agian .......changed oil pres sending unit at 150 bucks! still happening put manual gauge and both reading same?????? just to see i changed filter and probly a gal of oil and oil pres went right up so i dropped the pan to check for cracked pick up tube dosent look like any however where the tube comes from pump into bottom of block there is no bolt holding tube in pump like the suction hose has i will inc. a pic soon i havent got to bypass valves because i broke 5/8 hex wrench tryng to get them off have to get a new one dose anyone have any i deas for me also the is no smell of coolant or fuel in oil not saying there isnt But there no indicators of it i am lost here everything i can think of so far hasnt been the problem
