I am looking to buy a brush cutter for my Cat 305C CR Vin# HWJ00577and I am trying to figure out a way to get continuous flow to my Aux 1 or Aux 2 line so that i don't have to hold the thumb roller switch on my right hand joy stick. I do have the second set of Aux lines on my machine as well but wasn't sure if that switch operated the same way being that it has that rocker switch that deactivates the swing feature and activates the Aux 2 line. I have a shop foreman at my auto dealership that is a genius when it comes to electrical and he said he could probably wire a rocker switch into that thumb roller switch circuit that could make the hydro pump think you were giving it full power at all times the rocker switch is on. Do you see any potential harm in that? Or am i just overlooking a simple function that my machine is equipped for that i just simply don't know how to use it? Also if I use the Aux 2 lines do they carry as much flow and pressure as Aux 1 lines?
Thanks for any help
Thanks for any help
