Broken bolts changing undercarriage
FarmWrench
Chaffee NY
Table Potato farmer
A logger friend has 7 bolts break on 450h rollers on an undercarriage change. Rental shop running 3 450j have had one bust off on the last 3 sets. A diehard Dresser man claims trouble free changes on his td8s and TD 15 e. "Always one" says the Cat guy.
My plan for my first farm dozzer is to get the best machine with the worst undercarriage and do the change myself. $8K for everything on 450h and most times a bad uc sets price back more. (Or am I wrong?)
So why the drastically different bolt breaking? Brand? Installation? Use? Salt? (Logger runs in salt a lot, rental-never)
Anti-seeze is your best friend when putting on new track pads or other components. Changed out a several sets of pads over the years, used anti-seeze every time and never had a broke bolt.
Now that I have said that, the D5 is coming up for a set of pads..:pointhead
Multiracer
Northern,Ohio
Owner/ operator
I could not agree more with what CM1995 has said.
I have found the copper anti seize is far better and longer lasting in the organic environment of off road stuff.
Good luck
Ron
CM1995, It's like I have said for years about using the anti-seeze in many applications when asked why bother. I say you should make it easy on the next guy because the next guy just might be you. For you POGO fans it is just a revision of the "We Have Met the Enemy and He Is Us."
Deeretracks
Western Washington
Shop Foreman
The pads are no big deal. The rock guard and roller bolts can be a pain. It does seem on the 350-650 JD dozers they break pretty easy since they are so small. I have the same issues on D4's also. You get good at welding nuts to the broken ones.
DJK
Central Ontario Canada
Deere dozers and anything case always has broken bolts..when doing u/c only thing I have noticed about the small td's is that there is no where for water to sit because it's a c channel side frames.. Just my observations and experiences.
FarmWrench
Chaffee NY
Table Potato farmer
Track rollers was what I asked guys about as it was brought up first. Never a comment about sprocket bolts or segments giving trouble. Cat D4h (early high track with lever steer at the dump) got nothing but hate for breaking the big bolts that held the front idler. Never heard about the back idler.
Copper anti seize is sometimes rated for Stainless steel but not always. On critical stuff I know I will have to deal with years later I run a tap and clean up with air/kerosene(I now will use Ultra low sulfer diesel) and make sure to work the never sieze in really good. It does pay.
Our soils eat all the steel on steel contacts before pads. No one has regretted the $20-40 a pad for new.
I still have about 1/2 a can of the Cat anti-seeze. Didn't Cat discontinue it? I know they didn't make it, just a branded it but what's the equivalent?
PAcattech
Central Pennsylvania
CAT field service tech (31yrs)
Hi CM1995 , Yep CAT has discontinued most all of its branded maintenance chemicals. tread locks anti-seizes and such but I think you'll find that most if not all dealers sell Loctite brand which is the same stuff. part number for 2.5 lb can is 1615524 8oz is 511447 these are Loctite part numbers . we order them with these part numbers though our parts system . here's a link to CAT / Loctite
http://www.proloctite.com/caterpillar/downloads/cat-global-catalog-na.pdf
Thanks for the link PAcattech. Loctite has some pretty interesting products.
simonsrplant
Alberta CANADA
Heavy Duty Off Road RSE
Anti seize for sure, don't forget your old friend the tap! I swear by running a tap through (most) threads in contact or close to dirt. Makes a hell of a difference when re fitting and torquing.
FarmWrench
Chaffee NY
Table Potato farmer
Never thought of tar. I have seen it used only in museum exhibits.
Can you elaborate?
What makes for good pine tar? Where would I FIND it? How do you use it? Heat?
ol' Grump
eastern Oregon
Years ago I did some marine work and taking stainless bolts out of aluminum or steel housings resulted in breaking many of the bolts due to corrosion. I'd tried several types of anti seize compounds and finally I tried some RTV silicone gasket maker. Viola, no more broken bolts. Since then almost everything I work on gets the same treatment. .clean and run a tap into the holes, put a dab of RTV in the hole and a dab on the bolt. I've found this works well on crawler undercarriage bolts. .it doesn't let water etc get into the threads so no corrosion takes place. Bolts break loose with about the same effort as it took to tighten 'em.
Bluox
WA state
Take the swing frames off the tractor ,turn them upside down and use a impact wrench.Makes the job much easyer and if a bolt breaks it can be drilled out.
Good luck
Bob
Scrub Puller
Yair . . . FarmWrench. 8k bill is exactly right, it is good stuff and can be obtained from a horsy shop or vet supply place.
Bill had the spelling a little wrong. It is "Stockholm" tar as in Stockholm, Sweden which is where the best stuff comes from. It is a pine tar used for preserving timber, ropes, horses hooves and what all and also very good on threads.
Cheers.
Randy88
iowa
Don't forget to throw the old bolts away and buy new bolts when you installing the new rollers or any undercarriage part, also buy the best bolts you can get, not just something off the shelf out of the local farm store.
g_man
Northeastern VT
Retired
I bought the same kind a dozer you are looking for. Ended up with a Dresser. I broke 3 rockguard bolts and one roller bolt and had to cut a few rockguard spacers also. Thought I was lucky with just that. I managed to get them all out by welding nuts on as said above and patiently swearing alot. I thought I was used to hard work until I did an u/c with back yard mechanic tools. But it can be done. Good luck.
D6c10K
Iowa, USA
Along with buying new bolts make sure you get the correct length bolts. Just long enough to go through the track frame but not much more. If the bolt protrudes an extra inch into the frame then you'll have an inch of rusty end to screw out through the threads next time you have to take them out.
I've been wanting to try some Stockholm tar for a while. Will any brand work? Here's one US supplier that claims to have good stuff....but not inexpensive.
http://tarsmell.com/tar.html
I've got a Jeep bumper rope that I'd like to preserve with it too....
Scrub Puller
Yair . . . D6c10K.
Never were truer words spoken . . . same thing with cutting edge bolts, they should be dressed off just level with the nut.
Things may be different now but grade 8 and better bolts . . . in Australia they used to be generically called 'Cat' bolts . . . were relatively expensive and I never viewed them as "consumables".
As well as a tap run into the holes rock guard and roller bolts were often cleaned up with a die or at least given a mechanical wire brushing.
Cheers.
