Brakes Locking Up--2003 Terex 860
DoubleNickel
Adirondack Mts, NY
Last Nov/Dec my rear Hydraulic brakes started locking up. I topped off the brake reservoir and the brakes were working fine. I didn't overfill it. Then it got real cold. Freezing cold. If I pushed down on the brake pedals, they would go down. By the third push the pedal would be right up on top. Brakes locked. Wait a few days, the pedal would go down again and lock up in the top position again. The brake pedal would not budge a pinch. I would leave it alone and in a few days, the same thing all over again. Left the machine on the job. Today (4-12) went back to the Backhoe. Same thing.
Could it be water in my brake lines? It is still freezing out. I will bleed the brakes when it warms up. Any ideas??
DoubleNickel
Adirondack Mts, NY
UPDATE: Fixed. I backed off on Pedal bolts 1/4" each and that has seemed to solve the problem. I think topping off the brake reservoir pushed the pedals up tight. Seems to work OK now. Knock on wood!! That was easy.
