HFservicesNC
I have recently got a older body style bobcat mini excavator and it did alright when i got it but now a week later i am having a few Hydraulic problems. First of all my rotating speed is very slow and my boom retract is also slow. The crawl, rotate, blade up and down functions awe very jerky a lot of the time and take a little bit to respond. I believe that it may feel a little under powered but its had to tell being that i never used the machine when it was new. The right side track is pretty week unless you use the left to help it but i figure that is the the motor going out. I also filled up the hydro tank because it was low and used the machine the next day and the vent was overflowing with foamy hydraulic fluid. I have replaced the filter and cleaned the drain filter. when cleaning the drain filter i found a little bit of brass which i figure came from the final drive but im not that worried about that. I would jus like all the other functions to work fast and without jerking.
My current rotations per min are - 3 manufacture specs are 9.3 rpm VERY SLOW
