Hey everyone,
Looking for some advice on a hydraulic issue with my Bobcat T66, I'm trying to diagnose a problem with the bucket tilt function.
The Symptom: When I raise or lower the arms, the first time the bucket tilt cylinder meets significant resistance, it has about 6 inches of slop/give before becoming rigid and holding firm.
Examples of the Issue:
Thanks in advance for any insights!
- Lowering the front of the skid steer: If I tilt the bucket down slightly and then lower the arms to lift the front of the machine, the bucket will "fold" up about 6 inches when it hits the ground before it becomes rigid and starts lifting the machine.
- Scooping material: If I tilt the bucket to the correct angle for scooping and then lower the arms into dirt and move forward, the bucket will fold down about 6 inches before it digs in and becomes rigid.
- If the last hydraulic operation I made was the bucket tilt itself (either tilt up or tilt down), the issue does NOT occur. The bucket will be immediately rigid when it meets resistance. It only happens when the bucket tilt hasn't been the immediately preceding hydraulic action before meeting resistance.
- No obvious external hydraulic leaks around the tilt cylinders, hoses, or fittings.
- Hydraulic fluid level is good.
- Internal bypass/leakage in one or both tilt cylinders (worn piston seals)?
- A problem with the tilt circuit spool in the control valve (internal leakage)?
- Possibly a load-holding or check valve issue allowing fluid bypass?
