Hello I’m new to the world of forums looking for some information guidance. I have a t200 bobcat I pulled it in the shop to replace a bottom roller and lift spool seals while I had the track off of the right side I replaced a drive hose “wasn’t leaking just had a worn place on it” put it back together and now it moves about 50 feet and the right side drive motor locks down I had a suspected a brake problem and sure enough I found one brake disc had chewed some teeth off. I cleaned all of the metal out and rebuilt the brake on that side ”seals,discs and piston” put it all back together and same thing so checked charge pressure 315 psi at idle ran for two min and pressure dropped to 250 and was falling when the low charge psi signal popped up Would a charge pump go out all of a sudden or do I need to be looking for a leaking spool or relief valve? Any help is appreciated
