I have a foot control T190 that has been having a sticking problem with the lift and tilt control. When I go to lower the bucket, it has a hard pedal which when pushed hard will allow the bucket to lower, but with a very sudden jump. We noticed that when the tilt pedal is touched at the same time, it will make the sticking lowering pedal work a little better. I looked over the linkage and found nothing and determined that it must be a valve problem. Since it's a T190, the lift and tilt spools cannot be removed with the valve body in place, so I removed it and have it on the bench. My question is should I also look to another part of the valve to repair while it's out or would this problem be limited to the lift/tilt spools? I should add that it's only been about 500 hrs since I rebuilt the spools due to a leaking problem and it worked perfectly until now. Any ideas would be greatly appreciated.
