Bobcat T 190 (2007) temp. press bar meters ( gauges)
slowstep
texas
retired insurance agent, went physical work
Anyone have any insight on Increment of measure-of bars on gauges , for example Hydrualic pressure bars = how much psi - temperature 3 bars = what temp (fahrenheit or centigrade). or do you just look at meter and say thats running close to center and that is ok or should you be aware of what these actual readings are. to perform proper maintenance. thanks
crewchief888
NWI
i'm assuming you have a deluxe RH panel?
:drinkup
slowstep
texas
Crewchief not familiar with the term RH panel does that refer to keyless panel . yes that is what I have. ? Does each bar represent a value? thanks
crewchief888
NWI
i've never heard of the individual bars equalling any specific temp or pressure, or voltage
since you have the deluxe panel, you can see actual temp, pressure and volts on another screen, i believe it says "machine vitals" or something similar
:drinkup
slowstep
texas
Thanks crewchief I will check for that screen tomorrow and tell you what I find.
slowstep
texas
crewchief located the vital read out that helps , I'm getting a oil pressure reading at 2000 rpm at 43 is that normal ? or is that a little on the low side.
crewchief888
NWI
all depends on
engine temp
weight of the oil
43psi @ operating temp dont sound bad to me.
you'll probably see 60 at startup, anything below 20 or so (even at an idle) and you'll be kicking up warnings, and an eventual low oil pressure shut down down around 15-17 psi.
:drinkup
LWG
Reisterstown, Maryland
That's about what my T-200 is (I know it's a slightly different engine). I see 20-22 at idle on a hot day, and 35-40 at higher RPM. I was running 5W-40 Diesel synthetic, but I thought that was a little thin. I went to 15W-40 Redline Diesel synthetic. I know that the bigger number is the same, and when at operating temperature the viscosity between the two should be similar, but it doesn't seem to work that way, the thicker oil seems to generate high pressure, even when hot.
slowstep
texas
thanks Crewchief and LWG for the info that makes me feel a little better, thought I might have been running a little low on oil pressure.
