bobcat s70 hydraulic question
amtun
I have 2018 s70 only 300hrs for home use. this is what I noticed after using it here and there . is it air in the hydraulic fluid? should I be concern about it? it also make some noice when using the bucket lifting up and down. sometimes, the noice disappear at low rpm . it is come and go. I also noticed jerky movement while lifting bucket up with weight higher than 3-4 feet off the ground. any thought or advice? the machine runs fine otherwise.
439503093_7503463843079609_6945307554588357072_n.jpg439422241_7503464086412918_5108799887915444748_n.jpg
crewchief888
NWI
looks like air in the oil to me.
check the suction hose between the tank and pump.
s70's (as well as 453/463) have a tendency to suck air in from the hydrostatic pump steering shaft seals.
