Bobcat s220 tilt hydraulic arm bushing replacement
Bvill01
N.m
I’m wanting to replace the bushings on tilt arms on my bobcat s220 what the easiest way to remove and replace them bushing thanks
Txhayseed
Texas
With any luck you can drive them out with a brass drift. Or a piece of pipe that will catch the bushing. Ive seen guys use a washer that matches the bushing diameter with a bold and a nut on each side. Hydraulic press or ball joint press. Then sometimes you beat and cuss them get the sawsall out and cut them. Lots of methods depending on what you got on hand. I like the ball joint press personally if you got one.
Bvill01
N.m
Thank you I do have one that bought years ago thanks for helping me out !!
