JPSouth
The 7-pin connector on my 2005 A300 loader arm got broken late last year, I got a kit and stole an hour of warm afternoon Friday to repair it. Went fine, but ran into a tool question.
I have a 3 piece Thexton Deutsch disconnect tool kit which I've used on Harleys and a few other odds and ends over time. The Bobcat kit included 2 disposable disconnect tools with the replacement connector, end cap, etc. A few incidents in the past have steered me away from using plastic disconnect tools unless absolutely necessary, so I dug out the 20-24 gauge Thexton to remove the terminals prior to installing the new connector.
The tool was the correct one to depress the terminal ears, but the connector access hole was very slightly smaller than the tool's probe diameter. The included plastic one worked fine, but is obviously meant for just one or two uses. I often work quite a distance from anything like town, and need to be able to fiddle with electricals on my skiddy if needed. Not really wanting to depend on plastic stuff, metal tools are superior to gently coax stubborn connectors. Besides, looking at the price of the plastic ones, if a guy bought several to throw in the war chest he'd have a decent set of metal ones paid for.
Looking at my 20-24 gauge tool, I don't think a guy could just hand-machine it down to size, the thing doesn't really have a taper to it and that's the biggest problem. Gonna check on the Snap-on truck this week and see what he might have. Never run into having the access diameter on Deutsch connectors be too small before, anyone else? Does OTC, S&G or another tool maker have a little different design that works on those 7-pin connectors?
